biggiephil
I wasn't sure if anyone had fixed the lock screen light turning off yet? I can't remember if someone ever did, let me know
thanks guys, appreciate it!
You mean the blacklight issue, no there hasn't been a complete fix for it. The issue ONLY occurs when brightness is at 100% so at any other brightness level the issue doesn't occur.
Hmmph that's odd..my brightness is at 0% and it's still happening
Really? It never happens to me me unless its at 100%. Last time I tested this was on PG's 8-09 build, I haven't tested the 8-17 Build yet. Are you running the lastest build?
Flashing my baseless paranoid fixes backlight
Its in my baseless ports thread. Links are a pain on my phone or I would post a link
Ohhhh, didn't know. ThanksThat's the right one. Go into "Paranoid" settings in the Settings menu. User Workspace, either of the first two options will put the bar back to the top. The Apps setting will allow you to resize any app, including settings, if things are too small.
I don't think I had the right one...this one put the user bar on the bottom of the phoneand reboot had a fire skull? Don't think I picked the correct version xD..
Nah, it's cool, just didn't know if it was the correct version lol. Anyway to make the "Settings" bigger? it's quite small lolyou can find a bootanimation changer on google play if you dont like the fire skull. lol
Just flash over paranoid with that one?if you dont like the settings screen on paranoid you can try liquid smooth it has a regular settings screen.
Lol...I reflashed paranoid. I'll deal with it lol. Is nova launcher supposed to be there?yea you cant flash it over paranoid.
Does the new 8-17 build fix the battery overheating issue and having less than 8hrs of battery life?
