Gerrymac40
Hi,
Have been using my S3 now since 2012..no problems until last summer when my Sandisc SD Card collapsed while on holiday in Orlando..Received a replacement from Sandisc and all working again. A few days ago I factory reset the device as it was slow and clitchy. No problems with that..Phone was flying again.
I started to put several apps on the SD card to free up the internal storage on device..there was about 10 apps. Last nite I sent a few texts and usually they send straight after hitting the Send button..but last nite they took over a minute/2 to send. My network signal was 3 bars and I could use the phone to call-so the network was fine.Plus the phone was acting strange..it was on but nothing visible. Had to take the battery out/in to get the phone to start again.
I don,t know why I thought of the SD Card..but I moved a few apps from the card to device..and then texts started to send immediately.
It,s a Extreme Plus 32Gb card...
I,ll do a few more tests...Has anyone else had a problem with either their phone/SD Card (Sandisc)
Cheers.
Cheers.
