Root phone always reboots into recovery first after running Bootstrap...
hasbrobot
Ok so I installed bootstrap and now everytime, yes everytime my droid X boots up into recovery first. Is there any way to stop this? From my understanding its supposed to either do this occasionaly or after a battery pull while booting. Is it possible to get this to boot normally like before I ran bootstrap? I understand the purpose of the recovery boot but does it have to do this evry time I shut down and turn on my phone? I thought I read somewhere there are 2 files of some sort that can be deleted to get this to stop but after a number of hours of searching, I've come up dry. Thanks for your help. By the way Im' new to the X, Traded my incredible for this.
i would try uninstalling the app
reboot make sure it boots up fine
then reinstall the app
hit bootstrap recovery
and then reboot and see if it boots into recovery
Tried all of that and nothing worked. Still booted into recovery first each time. I may just uninstall clockwork. Thank you for your suggestion though. Iam in no way new to android so I now this can be fixed somehow.
it will also boot into clockwork recovery if your phone is plugged in.
I dont really have any solutions for you but you can try contacting @koush on twitter
I had this problem back in the 'FLYx' rom days. It went away on its own, but then again that's when everyone was SBF'ing. So I'm assuming the SBF is what fixed it.
As annoying as it is, you shouldn't try to sweat it all that much.
Are you running a custom rom?
Try looking under the CWM settings or rom settings to see if you have it booting up recovery all the time.
