txheart0711
My Samsung 3 (SCH-I535) is not seeing/connecting to my pc. I run on a Windows 7 laptop. Using the USB cable, the computer doesn't show the phone and I don't get a message on the phone saying I'm paired. They just don't "see" each other. Incidentally, moving the usb cable while it's plugged into the phone will turn off/on the charging. It's like it doesnt have a good connection.
I decided to try bluetooth. I turned on the bluetooth on my phone and tried to follow the directions found on multiple websites to pair a bluetooth device with my pc, but every single one of the instructions said something that I couldnt find. For example, one said to go to Start, then My Network Places - no such thing. Another said Start, Control Panel, Hardware and Sound (for a bluetooth device? okay ... ), then to right click Bluetooth - there is no bluetooth option to right click. I even bought one of these things that you can take out your card and plug into an adapter for an old phone, but if I'm not mistaken these dont even have a card to plug into it. How the heck can I get these 2 devices paired? Any advice is sincerely appreciated.
Ky
Ky
