Help Phone answer screen too dim
kDub1611
Since I upgraded to ICS I have noticed that the screen when a call is coming in is much more dim than before. Before the upgrade I could clearly see which way to move the slider to answer or ignore a call. But now with ICS the green and red icons are so dim that I can barely see them indoors and cannot see them at all outdoors.
I know that the simple solution is just to memorize which one is on which side but I just don't get enough calls to remember.
Is there a way to correct this? I really don't think it's a problem with the brightness settings because otherwise everything is fine. Can I get a customized phone answering screen or something?
