There is a bug in 2.2.1 where the "init" process will run constantly at like 70% cpu and slow everything down. I don't know what turns it on, but once it's running, it's curtains. Download OS Monitor free from the Market and run it and see if "init" is running as PID 0, and running constantly. You can't force it to close either, it just starts up again.
The work around is to go into Settings / Applications / Development and turn USB debugging on, then reboot. I have no idea why this works, I found it on another site for another Motorola phone (Droid?). But it does work if this is your problem.
AWESOME!!!....got my Defy back to normal
great app thanks. do you know anyway you can turn off certain programs for good (apart from uninstalling them) like ones that came with the phone, one being Social Networking, that's using loads of CPU.. i can shut it off but it keeps restarting.[/Q]
I use a program called AntTek App Manager to "freeze" certain apps from running. Hopefully that'll work
