Phone reboots automatically sometimes
ok.no sir. I have not installed it.
try to flash it again and after a sucessfull flash do a hard resetI updated Galaxy Y couple of days back via kies to DDKL1 (India) firmware. And ever since I am getting boot loops! The phone gets restarted every few minutes. Does anyone know what the problem is and how to solve it?
try to flash it again and after a sucessfull do a hard reset of the then use it ....
you have to hard reset after updating firmware
now you have already flashed a new firware after that bootloops....before flashing againFrom where do I get the firmware file for DDKL1? I had got the update via Kies, I don't have the firmware file saved anywhere. Earlier I was on DDKJ3, which also used to reboot 5-6 times a day, but now with DDKL1 it is rebooting endlessly (boot loops)!
So which firmware to flash and WHERE TO GET THE FILE? Pls give me a Download link for Stock firmware. And is it to be flashed via ODIN in the same way I flash ROMs on my Galaxy S II?
take a backup of phone and do hard reset now see if this solve the problem if no then to you have to flash it again
you said you flashed a new firmware a few days ago right..now i am telling you to do a hard reset of your phone which may solve the issue of bootloops you are getting if that doesn't solve.try to flash again..
or take it to a service center
use the search button first
http://androidforums.com/samsung-galaxy-y/458806-download-latest-firmware-indian-galexy-y-s5360.html
Well "hard reset" or factory reset is always the last resort. Thanks for the download link, that's what I was asking. But the link is of an OLDER version of firmware KK1, where as the latest firmware in India is now KL1. So you want me to reflash to an older version? Can I have the link to KL1 or later fw than that. And you didn't answer whether the procedure for reflashing is the same via ODIN?
hey can anybody help me.. pls help me bout my sgy.. after i follow d process on nstaling creed's rom.. after rebooting.. home screen not runing.. after seeing the brand name on its opening. it doesnt proceed to home.. its just a dark monitor i only see.. wat shud i do?//Root it then.
