My Galaxy Exhibit 2 was running a little sluggish last week while it was running the Opera browser. Not sure what the problem was.
But I did the trick to reset the phone, by removing the battery while the phone was powered on.
After a few minutes, I put the battery back in and the phone would not power on. I figured at this point, something happened to it and it's now bricked. When I plugged it into the AC charger, it didn't light up with the charging indicator. "Definitely bricked." was the thought.
I pulled the battery and placed it in a drawer, figuring it was history.
A couple of days later, I retrieved it and placed an aftermarrket battery (RayOVac) inside it, thinking that the OEM Samsung battery might have caused the phone to cease operating when I pulled it.
I then plugged in the charger and the phone lit up. I let it continue to charge the RayOVac, then when it ws finished, I put the Samsung battery back in it and that also charged up.
When I put the SIM back in and it connected, I did a Factory Reset on it for good measure, in case it was a software issue and the phone has been fine since.
So, if it looks like your phone might be bricked, try leaving the battery out of the phone for at least a few days (if you have a spare phone you can use in the interim) and you might be surprised.
