Phone Calendar Sync Issues
utkevjack
Events entered into my google calendar on my phone are showing up as stored on my phone but not appearing on my google calendar on the web. When I went to sync it with everything else on my settings it won't let me select sync as an option (there but won't highlight). Is there a solution to this. Droid X with stock Gingerbread.
Menu-Settings-accounts-@gmail... is calendar checked?
Yes it is. The tab I need to select to sync is under google calendar-menu-calendars-phonestorage. It wont let me select where it says sync.
Cableguy is telling you to go to any homescreen, then press Menu->settings-Accounts-><name of your gmail account>->and make sure that Sync Calendar is checked.
If that doesn't work, I'd delete the Calendar Storage data on your phone and re-sync.
