BullsBeers
When I click the phone icon, is there a way to have it default to recent calls instead of keypad?
Dialer One, free download from the market will do what you want.
https://play.google.com/store/apps/...lerOne&feature=nav_result#?t=W251bGwsMSwyLDNd
So with elixr i could make a widget to open the recent calls list? In that case the user would simply hit the widget instead of the phone button? After that all would work the same correct?
