phone camera
  • Start date Start date
A
Android Question
Guest
how can i fix the camera after it says force close or camera failed
There are essentially two parts to the camera. The physical electronics and the software. A force close could indicate either problem. First try to use a different photo app. Vignette for example. If that doesn't work, you might need to have the camera repaired.
