Hi all,
In my car I have a netbook, and a usb touch screen in the dash, the power/usb/video to the netbook in the glovebox is all in behind the dash, so you can unplug and wip the netbook out the glove dead easy, and I have a bluetooth remote.
I use my HTC Desire, with the hotspot app, so it wirelessly shares its internet with the netbook, so internet surfing in the car as well, apart from this the phone just charges from 12v, and its conected to my bluetooth headunit for calls (Netbook is on headunit AUX so it mutes when I'm called)
so... I have this little usb relay board from ebay, its a printed board with 10 relays on, so you install some very simple software and then when you click a button on the software, the relay fires. You can change afew settings, delay, if it goes off or stays on... its orginal use is home automation
So I've put this behind my dashboard and plugged it in my netbook, and wired it up to the central locking, inside lights, outside lights, ignition, and heater controls (took some doing that one did)
I have used my phone with logmein on to view my desktop remotely, and using the relay software test this, and it works a treat, my phone controls my whole car (very handy on a cold morning, I can start the car and get it warm before I get into it)
I've managed to perswade a friend of mine to write me some more software for the relay board, that sits in the start bar, and with a click brings a small window up with buttons on named what they do
But the problem is, I can only do it when the netbook in the car is conected to the internet via my router at home (it just about has range to reach the car parked on the front drive)
I cant control my car with my phone (when im out away from the house) because the netbook dont have internet
I need a remote desktop program that uses something other than the internet to work... and I'm not having alot of luck! wifi or bluetooth could work...
Thanks for reading!
Thanks for reading!
