Phone Case Glitch?
hellsrage619
So when i bought my X10 i got a hard phone case with it called incipio (dont know if thats the manufacture or a name for the case?).
Anyway when i put it on the phone the phone begins to glitch out like when im at the home screen and i try and slide to another it stops half way and glitches back and forth and just lags as well.It doesn't do it anymore guess i just broke the case in finally?
Anyone have that happen to them its really weird?
Some of the cases interfere with the hardware buttons which can cause strange things to happen on the phone. Could it be this?
ya when i had a soft shell case on my x10 the screen locked up because i believe there was pressure on the camera button on the side or something so it locked the screen. soon as i removed the shell it worked again. or if i even have it in my car holder tightly it locks up and you cant power it up from stand by. weird stuff. this phone is quite glitchy i think
Yes.When i have mine on the camera button sometimes doesn't work but it also does that without the case.
Has anyone had problems with the camera buttons?
Maybe its just common.
Have an Otterbox rubber one on mine and it is great. The fit and finish of it is excellent. Absolately no issues with it.
