Help Phone charging question
kollarism
Member
Quick side note--I'm not sure why everyone is complaining about the battery life. I easily get 16-24hrs of moderate use. I came from the Samung Captivate, and it would last me 12-16hrs MAX on moderate use. Anyway...
I noticed that the battery actually charges very fast...probably a full charge in 1.5hrs. I generally plug my phone in overnight. My questions is, does the phone stop charging once it hits 100%, or is it harming the battery to keep it plugged in overnight?
I have always left my phones plugged in overnight and never had any battery problems from that. I would say maybe leaving it plugged in for days multiple times might not be recommended. When you are charging your phone is it off or on? If it is left on while charging then it will be using power. Sometimes I noticed when I charge my phone while on and it reaches 100% and I take it off a little bit after it will immediately drop to maybe 98% but when I charge it off and turn it on at 100% then the battery meter shows 100%
As far as I know, the only devices that know to shut off charging when fully charged are iOS devices, ipods and iPhones. I don't know about any other phone doing so. I unplug my phone as soon as it hits 100%. I rarely charge it while it is on, usually I plug it in when I get home and leave it be.
I always charge my phone while it's on. Mainly because I have my phone as my primary way to contact me. I use the Battery Minder app, and it always shows me 100% after charging. I guess if there is any harm to the battery down the line, I can just buy a replacement.
