Phone clips
George66
Hi. I had a message that phone storage was low, so I transferred all my phone clips to SD card. When I looked at them they all have what looks like a lightning strike through them. How do I fix this please ?
Fake or duff SD card possibly? If it's a new one, where did you buy it? Suggest you check its integrity with SD Insight. I assume the files with the lightning strikes through them won't open or play now.
Thank you Mikedt. You are correct. None of my clips will play, although the most recent one I took and transferred does. Maybe I should have sent them separately and not as a block.
