I am having a problem where my Razr Maxx connects to my wifi at work, but no data is transmitted. The wifi bars are grey/white instead of blue, the phone is being assigned an IP in the proper range and the gateway and DNS are correct. If I try to go to Gmail or the Market it says "No connection - Retry". If I try to browse the Net from the broswer, it just says "Web page not available".
The phone used to work fine on this network until we had a problem and IT reset the router. It also works fine with every other wifi network I've tried it on. I know that indicates it's not the phone, but the IT department is giving me grief because every other wireless device including laptops, wireless printers, iPhones and even a couple other Android phones are all connecting and transmitting data just fine over this same network. My Razr Maxx is the only one having any problem.
I have tried "forgetting" the network and re-connecting. I've done a factory reset on the phone. I even tried my wife's Razr Maxx and it does the very same thing as mine on this network. I called Verizon and they don't have a clue what's wrong and say it must be a setting on the router (which makes sense to me since it worked until the router was reset.).
Does anyone have any ideas or suggestions on what the problem might be?
