Help Phone constantly vibrates - please help!!
withnail
Recently unlocked/re-rooted my Orange San Francisco to a Swedish Spring 2.2 operating system.
Worked great but after a few days the phone started vibrating and I can't get it to stop!! Any ideas? Would be very grateful for any help.
Yes still does it. Even taken the sim/battery/SD card out overnight. Continues to vibrate!! Phone still functions normally apart from this. Also tried going back to a 2.1 system, still no good!
Any ideas?
Thanks for help.
I was going to suggest checking the settings etc, and a factory reset, but if it's still doing it after reverting back to 2.1 that sounds like it might need to go in for repair. Revert to the stock ROM, remove all traces of clockwork and take it back to the shop I think....
Sorry mate.
Ok thanks for response.
If anybody has any other ideas would be glad to hear before I take my sorry ass into an Orange shop...
yes still got same problem.
Any hints/tips on how to install this TPT update or on how to wipe everything off my phone?
Many thanks for help
Thanks for all your help!
I've got it back to running on the orange settings and sent it back for replacement/repair - fingers crossed.
Could not find anyone else with same problem as me, mystery...
