Do you have your contacts syncing to Google? If you do, the easiest way is to log into your GMail account from a PC. Delete / Edit the contacts you want and the changes will show up on your phone the next time it syncs to Google's server.
I'll try that. I had them deleted once, my daughters old contacts, and it was good for awhile then all of sudden they appeared again. I thought out might be from our verizon account.
It's not from Google. It has to be from my Verizon cloud account. If there isn't anyway to do it on the phone I'll have to check Verizon's syncing out.
You won't find them as files in a folder. Like other app data they will be stored in a database in the /data/data area, so you need to use the contacts app to edit them.
If you think that the VZW sync is overriding your edits then you will have to check that out.
