Carphone warehouse kindly transferred my phone numbers from my old sim card to my new Desire phone. i have now noticed that they all say that they are mobile numbers yet this is not the case. What if anything can I do to remedy the situation? Can I remove the 'M' tag from them?
If they set up the contacts correctly as Google Contacts, they should be synced with your gmail on your pc. Its MUCH easier to login to gmail on your pc, and edit contacts on there.
I used to keep all my contacts on my sim card but I belive that carphone warehouse transferred the from my old vodafone sim to the Desire's phone rather than the new sim. Is it better to have these on the phone or on the sim?
If you keep them on the SIM you can only have one number assigned to one person and haardly any more information. If you put the m on the phone you have lots of numbvers you can add, addresses, IM numbers, etc., etc.
