Help Phone crapped out
exile_fg
My Note has worked quite well since I bought it new a couple of weeks after the initial release, but last night it crapped out on me.
I plugged my phone into the wall charger after the battery died. I turned it on and went to set my alarm and it came up with an error MTP application has stopped. I reset the phone and it seemed to work, I woke up before the alarm this morning so I don't know if it really worked or not.
When I woke up I tried to download a file from the internet and it said I needed to connect an sd card, there is one in it. All day long anytime I try to use it I get a list of errors.
TwLauncher has stopped
android.process.media has stopped
system process has stopped
internet has stopped (I wasn't using the internet)
Those are just the ones since I started writing them down to keep track.
I would rather not do a factory reset and lose all my data, what can I do?
maybe try under storage to dislog the sd card then turn the phone off take out the battery and sd card then put back in see what happen.
I can't dislog the sd card because I can't access the storage section of the settings, but I am going to try pulling it out and the battery.
ok but you need to put back in the sd card maybe you just needed a knock on and off. which note you have and version os?
