Help Phone detected by USB port but not charging
suybeen
The phone is C771 (Verizon Casio G'Zone Commando). It's detecting the USB connection but not charging for some reason. This started happening only after I reformatted to Windows 8. I did make sure to install the drivers.
Anyone know what could be causing this?
Thanks in advance!
That's strange - it's usually the other way around: it charges but isn't recognised.
The vast majority of connectivity and charging issues are due to defective USB cables - seems they're easily damaged. Have you tried a different cable?
Wild guess, but if that's not it, I would check if Windows 8 power management maybe disabled power to the USB ports .. That's usually an option in the reboot / F2 (or whatever) setup, but maybe Windows 8 is doing something clever ..
Okay, thanks for responding, it seems like the cable is fine but there's a problem with the computer's connection to the phone. However I now have an adapter for the USB to the wall socket, and that works fine. Thanks again!
I had to set mine to mass storage device for it to charge from a computer USB, the charge only option never worked.
I was able to get the charge only option to work. I just installed the drivers, plugged in the phone to USB mass storage mode, let the drivers install, switch to charge only, and it worked after those drivers installed. I also have adb on, so that might help as well.
