So evidently you can't use the phone while it's charging without draining the battery with the stock 1 amp charger.
It's even worse if you are trying to use the GPS. Glad I wasted the money buying a car dock.
Why they would supply a charger that wont even MAINTAIN it's charge while being used is beyond me. Garbage.
Anyone find a higher amp charger that works?
Thanks!
Thanks!
