Root Phone does not boot up
dpshptl
Member
I was on the XDA site and decided to remap the faves button with navigation. I followed the instructions given here,
[MOD]*New Options*>>Re-map Faves or Personalize button to any app<< - xda-developers
The phone just gets stuck at the green circle with my in it at the very begining. I did the vol down and power button to get to the boot screen. I noticed when the boot log was scrolling it said loading image and underneath it said no image. I tried to boot the phone a few diff ways but nothing happens. When I go into recovery and choose an option from there the screen is just blank. I also tried to do a factory reset but the screens just goes blank but its lit up. What I did was download the zip file to the root dir of the SD card and opened ROM manager and picked install ROM from SD card. I also did a back when it asked to. The back up took 10 mins or so and then the prob started.
It looks like the no image msg I see is coming from the SD card. When I remove the SD card that msg does not come up.
RESOLVED
I was making a mistake restoring the back. Got everything working fine.
