I use Windows Xp and the stock USB cable that came with the Behold 2. When I plug it in, nothing happens on the phone or the PC. Samsung says:
From any home screen, tap Quick List > Settings
Scroll down to and tap Phone Settings > USB Settings > Mass Storage > Save
Connect the data cable to the Behold II and a PC or laptop
When the Notification Bar indicates "USB Connected" tap, hold, and pull down
Tap USB Connected > Mount
On your PC, if prompted, allow USB drivers to be installed.
I never get the notification in the bar and windows does not see the device. I've also tried the Samsun Studio setting - no luck.
Phone is set to Mass Storage default.
16GB SD card installed.
I've tried it on two different computers both running XP; same story.
USB debugging is on.
I've installed the drivers in this forum and still nothing.
Sounds like a problem with the phone connection or the cable. Thoughts?
