Help Phone does not show up as drives..
lomicka
I have a new Samsung Galaxy. When I plug it in via USB the two volumes mount device manager but they are not assigned drive letters I can use. I am using the default USB drivers from 2006 on Windows 7 64 bit. Any help would be appreciated.
Thanks,
Steve
Without Kies installed I was able to work it fine. I select mass storage, and then drag down the (I don't know what it's called) from the top of the screen, press on the USB connected and tell it to mount the drives. When I do that the internal SD appears in Windows as a drive.
