A
Android Question
Guest
Apart from those two things the phone works fine. (Galaxy s3). Also you can see water bubbles in both camera lens and the camera image is blurry. Also the led light flashed on and off. I did take out battery sim sd card and left on carpet to dry but camera is still fuzzy and led light is flashing on and off so what shall I do???
THANKS IN ADVANCE
THANKS IN ADVANCE
