nickdalzell
Extreme Android User
I've made sure to uninstall most of my apps and removed 1Mobile Market and re-enabled Google Play, and cleaned up a ton. but this issue persists. my phone is a low-end Android phone (runs Froyo, unrooted) made by Samsung (i'd post to the proper forum but it appears dead or otherwise inactive) and if i'm playing music from either the stock music player or even Play Music, for any length of time, the music starts cutting in and out and if i try to unlock to stop it, the phone is unresponsive, and seems to have an out of memory issue. the background is live and appears to keep animating but my lockscreen is frozen and refuses to respond to touch. the clock shown on it also is stuck. sometimes attempting to unlock over and over causes haptic feedback 'pulses' and the phone's music gets even worse and more choppy. the only solution is to pull the battery (my old BlackBerry Curve had a similar malfunction, also when playing music ironically, and battery pulls were the norm for BlackBerries)
the issue ONLY happens with the music. and ONLY music stored on the SD card (tried different SD Cards and they all have this problem) and whatever happens, even if the phone is working great, it acts as if CPU and RAM usage skyrockets all of a sudden. it is NOT an app, NOT dependent on one particular music app, ONLY happens with SD Card mp3s stored and read, and ONLY with the screen off and locked as normal usage. is this some kind of Froyo/Gingerbread problem? (it also happened on other devices that ran both versions, so it's not a phone-issue) it also happens in Airplane mode so mobile network/wifi has nothing to do with it. it's not convenient to have to reboot one's phone at work because of this (i use music to help me work when i'm doing a long job) and it does not matter if it's been on for a week or turned on the first day of the week. i cannot nail it down to one app, bitrate of song, or a problem with the SD card itself. either the phone has issues reading the SD card at random causin this or something is suddenly jumping up reading on the CPU and RAM even if all i have is stock apps going.
the phone has NO other problems, never crashes or displays ANRs, has excellent battery life, and never phantom boots, this is the only problem and a very annoying one as i cannot pinpoint its cause. Android ICS and JB seem immune to this bug also, meaning it has something to do with how GB/Froyo manages itself.
