Help Phone froze and restarted
No need to do a factory reset, it's blank from the factory.
Probably just a glitch, happens every so often with Android devices. If it does it regularly, then it might be something to inquire with Verizon.
i got a text then my phone froze then restarted itself, anything to worry about ?
Mine just did the same thing. Not sure why it happened as this was the only time it ever did that.
i read somewhere that you should do a factory reset before using it, is that right? ive had a while
A factory reset is one of the best things you can do for a new device prior to use. Doesn't matter that it's "new." It assures you're starting off on a clean slate.
