The Space Ace
Hi everyone. I'm new here and I have an absolutely infuriating problem with my S5 that I can't seem to fix. The phone will randomly freeze up, shut off, and reboot. Sometimes it will do it once and other times it will go into a boot loop until I remove the battery, which is the only way I can get it to stop. Sometimes I'll even power it off only for it to restart itself automatically. It also tends to get very hot very quickly when it goes into boot loop. Right now it's at the point where it does this so often that the phone is pretty much useless. I would really really appreciate any insight you guys can give. Here is everything I've done so far and any other useful information:
- My carrier is Verizon and the model is SM-G900V, and I'm in the U.S.
- My phone is not rooted and everything is up to date.
- There are currently no third party apps on my phone.
- This may be related to the Lollipop update, as it didn't develop this problem until after that.
- The first thing I did was take it to Best Buy (I got my phone there), and a Samsung associate directed me to download a new software update. I downloaded it and the problem immediately returned.
- I tried a factory reset, which took hours to do because the phone went into boot loop over and over during the process. After completing this, the problem came back 1-2 days later.
- I wiped the cache partition but the problem immediately returned.
- I tried launching the phone in Safe Mode a number of times, but it still freezes and reboots immediately.
- I was directed to download Verizon's Software Upgrade Assistant/Repair Assistant application on my PC. It automatically downloaded some sort of update and my phone was good for two days. However, I am unable to use the Assistant because it doesn't detect my phone, even though my PC sees it. It will read something to the effect of "Please connect your device. If your device is already connected, disconnect and reconnect it." However, upon doing this, or any time I connect the phone with the Assistant running, the Assistant throws up a small window that says "Your device's current firmware version is unsupported to update firmware." I don't know what this means or if there's anything I can do about it.
- The Software/Repair assistant won't even open at all if the phone is not booted. Sometimes the phone will be in boot loop until it fails to start, at which the screen directs me to use the Repair Assistant on my computer, which is useless, because the software won't even run unless the phone is booted up and running, but the software doesn't detect it when the phone is booted up anyway.
I'm pretty sure that's everything I've done. Everything I've done above is everything I've been able to find so far on the Web. Thanks in advance!
