kristalsoldier
Hi...
While technically this should go into the forum for the Samsung Galaxy Fit (GT 5670), but I thought this may be a more suitable place for my question. But mods, if you think fit, please move into the appropriate forum.
Also, I have checked some of the threads dealing with phones heating up but did not gain too much from them.
My question:
Usually, I turn on the Data connection on my phone, activate the Mobile AP for wireless tether to my A500 tab. On the phone I turn off auto-sync. I have been doing this for sometime now with no bad stories to tell...till today, that is.
I followed the same procedure today and everything worked fine for some time. However, at some point, I lost my data connection and reached into my pocket (I had put the phone in my jacket today) for the phone.
Two observations:
1. The phone was very hot
2. The phone seemed to have shut off and had restarted because it appeared to be on safe mode. First time I have seen a phone in "safe mode"!
I was very taken aback. So, I turned off the phone waited for a few minutes and turned it back on. Safe mode was off. No problems in establishing the data connection and tethering it to the tab.
But given that the phone had heated up to the extent that it did (it was hot!) I did not use the tether and data connection for a long time.
My phone is unrooted and is on GB 2.6.35.7 and the tab is in HC 3.2.1.
I know that the phone is a low-end device and I use it primarily for voice calls but essentially to establish a data connection and for the tethering.
What do you folks think? What caused this? If the cause is the phone, then could you please suggest alternatives (as I am in the market for a new phone anyways)?
Thanks in advance.
My question:
Two observations:
Thanks in advance.
