phone hot after power off
  • Start date Start date
A
Android Question
Guest
Why is my galaxy ace hot despite power off and battery drains extremely fast
I'm not sure, but that sounds like the battery may be dying. Batteries are generally only expected to last 2 or 3 years which I guess ties with the age of the phone?
You probably want to replace the battery before it burst into flame :eek:
^^^ Good advice!
Also, check to make sure the battery is not loose and is making good contact with the phone that might also account for the quick drain.
