phone is not reacting anything sd card, usb driver, even not show in computer...
Elnur
Hello guys i need your help after deleting rom i taught i will open just TWRP and use usb-otg and install another rom. But phone is not responding at all to flash driver, sd card even computer can not see. All drivers was installed on computer when i use command "fasboot devices" it won't show up. It is not responding at all what i do not working almost done everything. Phone is charging normally also. What can be reason ?( I think it is hardware problem :(
First of did you make a nandroid backup? If not then this will be a very hard lesson to learn..... always make a nandroid backup before flashing anything especially a custom rom.
It is one of the main functions of twrp.
So can you get into twrp or not? If not what happens?
Yes i can get into twrp but can not transfer any rom via sd card, pen driver, adb fastboot mode. Also i mentioned that happened after my phone survived from water. Phone was not charging first after drying it charged and worked normally. but phone was not opening pen drive(FAT32) using usb-otg and i taught it is rom problem and i deleted rom to try install another rom using pen drive in twrp but not responded again. Used sd card that normally opens in another xiaomi phone but not responds in my phone. Even opening fastboot mode and installing rom using adb not works. All drivers correctly installed.. What is the problem ?( Can water damage affect some particular thing that can lead to not response of any external storage ... But it charges how... It is confusing like if it was water damage sd card was working normally...
can't you just remove the card, transfer the custom rom to the sd card, insert the card back into the phone and try to flash rom with twrp?
You think i didn't try ? i used everything possible but not works.. i need some another solution that someone can say..
It could certainly be water damage, has quite possibly shorted and fried something, or corrosion damage. If that's happened, it's new phone time.
Was is completely and absolutely dried before trying to power it up, although with a sealed battery that maybe difficult.
You are right i think also because after water damage phone was not dryed immediately because i didnt know about water damage phone was in my pocket.. i mentioned water damage when i was trying to charge my phone and not success But after drying it out everything was working really good...
