Phone is noticably hotter when charging from a PC USB
Tenchiro
When I charge from a PC I notice the phone gets warmer than when charging from the wall. It is not hot by any means but quite a bit warmer than simply charging from the wall.
I don't think it will cause a problem and may be normal but I just wanted to make sure.
Thanks
Actually, that's strange.
When charging from you PC, your computer's USB port should provide 500mA (since it runs at 5V, that's 2.5 Watts).
The charger for the G1 can actually provide slightly more power (I don't have one in front of me, but I believe it's spec is something like 600-650mA). That's why your phone charges faster with it. That's also why I would expect the phone to get somewhat hotter when using the dedicated charger.
An explanation would be that your computer doesn't fully adhere to the USB specification (which is quite common).
Thanks for the reply. I can see how a loose USB spec could affect that but it seems to be an issue across multiple computers. The T-Mobile My Account app gives some battery diagnostics but doesn't give an indicator for USB power. I wonder if there is another app out there that will tell me how much power I am getting from USB on different devices.
Is USB debugging enabled? Or sd card mounted?
I've noticed this too.
I assume that it's interaction between the computer and the phone (even when I don't have usb debugging or usb storage on?) I suppose it's doing SOMETHING even though were're not aware of it...
Nothing should be happening unless debug mode or sd storage is on
