Root Phone keeps rebooting on Volume Up + Power (trying to install ROM)
a7474
I tried to install Android's ROM and got ERROR 7, then I wiped out cache, data, internal storage, where was twrp.apk installed.
After that I cant get into boot menu (with Install, Wipe... buttons).
Then I copied twrp to the phone:
sudo fastboot flash recovery <twrp.img>
Tried versions 3.2.1-0 and 3.4.0-0, because I heard for certain phone (I have Xiaomi Mi4) it's necessary to use proper version, though I don't know which.
What's going on now: I can successfully can get to the nice splash screen using Volume Down + Power, then on my PC I give sudo fastboot reboot command and press Volume Up + Power and here is the problem: It has no effect, it just keeps rebooting (I see only Xiaomi's logo).
