Help Phone keeps write-protecting microSD card
MSmart
Yesterday, I rebooted my phone. That is, turned off the phone and held the power + T keys. I have a 16 GB SanDisk MicroSDHC that was working perfectly up until then. Then, when I put it into my computer to add files and such, it locked up and said something like "Please insert disk into drive H:".
I tried formatting it with Windows and a program from SDcard.org, but no luck because apparently, the card is write-protected. I've checked the switch a million times, and the problem is not the reader itself; it worked fine with another card of the same brand.
I was successful in formatting and adding files in Puppy Linux 5.3.3, but the moment I put it back into my Gravity Smart, it becomes write-protected and formatted all over again. But it's not doing that with this other card I have. What gives?
