Help Phone not charging?
Is it the BIONIC charger or the D1 charger?
Actually, that really shouldn't matter b/c I'm using my D1 and BIONIC chargers interchangeably for charging both my D1 and my BIONIC< and all work on all.
Since you have a D1 *and* a BIONIC, is this with all the chargers that you have? If so, it might be a bad battery (if so, you should see a ? in the battery icon).
Upvote 0
BEST TECH IN 2023
Smartphones
