phone not recognizing sd card
cotts135
Just got my ouku horizon and currently the phone is not accesing the SD card. Now the card is a 8gig card and the horizon can read up to a 16gig card. Would that make a difference or is there something in the settings I need to do. Any help would be appreciated. Thanks
Should work, have you tried the card in your PC first to make sure it works, also where did you buy it, it is easy to buy bogus SD cards, so beware.
