Anyone who is having the problem where your phone will only vibrate, not ring (even with volume maxed) try the following. Its a bug due to Smart Profile and has been reported on the Motorola site. I was messing around trying to get it fixed because there was no way I wanted to factory reset my phone like was recommended by Motorola. Its odd this worked even though a battery pull did not, but that's technology for ya!
Download the free app called "System Panel" from the Google store. My version is the paid one, which makes the app run in the task bar for easy use but I don't think it matters if you have the free or paid version. The program is a task killer but seems to be more advanced then the typical task killer app.
I had the following settings checked; I don
