Help Phone Numbers!!
Renniks
Hi All
With transferring Phone Numbers would it just be a case of importing from SIM on the first time of putting the SIM in?? As I don't use GoogleMail, and yeah I know I will have to for Apps, but that will be all's I will be using it for!
Thanks for any help
Lee :)
Once you have got them from your SIM card, it is soooo much easier to then store your contacts with Google, and you don't have to use the Gmail interface for contacts, you can use this - http://www.google.com/contacts (you'll need a Google account obviously, but you'll need that for using the play store anyway like you say
I could never go back to SIM contact storage or even just storing them on the phone and then using sync software to sync it to your PC :(
