Help Phone or SD Card problem?
Sptz
I have my desire rooted with redux 1.2. First time, everything was ok until I got the "Preparing SD card- Checking for errors" thing on the notifier, even rebooting didn't do any good, launching any apps wouldn't work. So I reflashed and today I tried to launch an app and crashed, so I had to take the battery out, reseat then boot up, same SD Card message on the notifier showed up. It's not there now but I can't access "Manage my Apps" or "Settings"... it just shows a black screen.
The SD card I have is the one that comes with the phone... is this a SD problem or a phone problem?
Cheers
It wont be your phone, try either backing up everything on your SD card then reformat and restore your rom otherwise just try a full wipe and reflash
I did that once and it happened even worse now (not being able to access settings and manage apps) and this is after what? 2-3 days of being freshly flashed... Should I buy a new SD card and see if it goes well? Or could it be Redux?
Thanks. I've got another question though. If I get or try another SD card, should I make it Goldcard as well to be able to flash?
