Help Phone/Radio locks up after large data use?
coolguy
After playing pandora, slacker or using other data intensive apps the radio locks up. The up arrow just sticks and the only recourse is to restart the phone. Anyone else experiencing this?
I did find if I turn off bluetooth and wifi(even though im not using it) it doesn't seem to happen nearly as often. Maybe its a heat issue?
I have the same issue if streaming some videos...works great for the first one or two..then same lockup with the up arrow permanently lit. I have to power all the way down and back up to fix it. Real pain.
Yeah I was noticing it with slacker. I turned off wifi and bluetooth(even though they werent in use) and didn't have any problems. I need to try with bluetooth active again when i have my s9s hooked up.
I have been experiencing the same issues when downloading podcasts or streaming. I have to reboot the phone.
Any known fixes?
