A Android Question Guest Oct 29, 2013 #1 How do I UNLOCK MY phone or in delete the need for a pin number.
girolez Often Off Piste Oct 29, 2013 #2 Hi If you are locked out of the lock screen see this helpful post http://androidforums.com/faqs/685025-lost-phone-locked-out-faq.html If you need a pin to unlock your sim you need to get a puk code from your carrier (or try 0000 and 1234) If your phone is locked to a particular carrier you need to contact them for the unlock code. Roger
