Phone Reset / Reboot / Playing around
smithey
Just for anyone that likes to play, or needs to reset their phone here is how
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1
after that if you open your keyboard and hold alt+L you'll get a menu that says:
Android system recovery utility E: Can't open /cach/recover/command
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset
- (What I chose, had to re-register, out of the box settings)
Ive paid to unlock my G1 and use it on the 3 network. If i factory reset will i have to reinput the code etc or will it hold it?
Hmmmm. I have the same question, but I do not see an answer.
That is my G1 is unlocked. I am using it on ATT. I need to do a hard reset, or at least change the Google account used with it as I want to use that one with my new EVO on Sprint.
I don't see a way to change the Google account without doing a hard reset. Is there a method to do this?
I would like to be able to continue to use my G1 on ATT without having to unlock it again.
