Phone-SD card
nesetceri
Is there any way to move the programs to SD card instead of Phone ? Some programs will give me the choice to move to SD card but many of them won't, eating my Phone space
Also... are there any other weather widgets I can install..Go weather is useless..does not have my location ,stuck in F instead of C etc
Welcome to android forums.
1) As far as moving apps to SD card, that is only if the app is set up to be moved. (You might be able to do this if rooted too.)
2) I use WeatherBug Pro for all of my weather updates. (They have a free version.) Try AccuWeather as well. Its pretty good.
