I believe I made a huge mistake buying an Android phone. I've tried to use this for about 10 months.
Currently the phone response is so slow, the screen doesn't light up for an incoming call! After the caller gives up, then maybe I can get the stupid phone to start responding to input!
If I tap the screen, it takes several seconds to respond.
Part of the problem is, I went 8G storage, thinking that using a big SD card would work for me. But if the Android system and it's apps won't use it, what good is it? Every app seems to require being on the native storage, and this is regardless of if I have it configured as an external removable SD card, or extended native storage. (I'm on Marshmallow.....)
Why do I have to constantly have to delete junk files as if this was an old PC?
Why does it take two hours of babysitting the device to update anything?
I'm thinking of doing a general reset of everything so I can survive the next few months (until I can go back to Apple), any suggestions? How do I do this?
Part of the problem is, I think Google Play brings all my music to the local native 8G storage until it's completely full and then this destroys performance. But this is only a theory. I don't know how to reset just that.
