Phone Stolen
Hello Aruninfotech. I'm very sorry to hear of your loss. I'm afraid there is nothing we can offer to help you retrieve your stolen phone. You need to contact your carrier and report the loss so that they might stop any data use on your plan. You should also file a report with you local authorities in hopes that it might turn up. Unless you have installed a tracking program on your phone prior to it's loss there is no way of tracking it's location. Be certain that if you had any secured information such as passwords on your phone to immediately change those passwords... such as banking, google, mail, etc. I wish there was more we could offer you. Thanks for joining this community and I wish you all the luck in the world at finding your stolen device.
Welcome and sorry to hear about your issue, if you did not have a device locator on it, you can force load an app from the Play store to your phone by your PC, Go to ANDROIDLOST and read up on force loading this app to your phone, and it will allow you to track your device, lock it down, and send messages to it, there is also a forum there that you get check to figure out how to so so.
AndroidLost No pre installation required
You didn't install AndroidLost on your phone? No problem! You can push the AndroidLost app to your phone from google market and initiate the connection to googles servers by sending an SMS with the message "androidlost register" to your phone.
You also try an app called Plan B which will also track your device and email you the info see both videos below
