personinneed
Member
Hi all,
I got a notification in my SE Xperia x10i(2.1)...saying that the phone storage is getting low hence not allowing me to download apps
.I have installed not more than 70 apps other than the one's pre-installed).i'm using launcher pro
What shud i do?..I would also like to know if it is normal that my phone space got low as i've installed 70odd apps?
suggest me a good app through which i can move stuff to SD card without any problem.if i have posted in the wrong section please direct me to the right section.
Any help is appreciated.
Thx in adavnce!
P.S. i've rooted my phone but havent done anything yet
.I have installed not more than 70 apps other than the one's pre-installed).i'm using launcher proWhat shud i do?..I would also like to know if it is normal that my phone space got low as i've installed 70odd apps?
Thx in adavnce!
