what he said, but if you dont wanna do that ya best bet is to get apps2sd and make sure everything that can be moved to sd is. Hopefully as more people get this phone (hopefully) theyll create roms with a2sd support. My optimus m has over 100 apps on it and I still have 140 mb of 200 mb free
If you feel adventurous you can try flashing darktremmor a2sd (Google for the Facebook, I would link but I'm on my phone)
Hmm I'm willing to give it a shot. Going to backup my Rom first. Will give you a post update.
Did use latest dartremmor. Update in recovery sucessful but all apps stayed in internal memory. Do i have to format my sd with sdext for it to work?
Yes. Set with no swap via cwm (or ultrjack?)
I can't get incoming text messages because it says text messing full, I tried clearing my threads but I can't get incoming text msgs...help
also, what is root your phone?
