It depends on which version of Android you have Chris (go to Settings, About Phone). Later versions may have the option built in to move to SD card. If not, there are apps to do it (Apps2SD for example), but many require rooting your phone (& therefore voiding your warranty).
Have you looked at the stickie at the top of the page?
