Phone Storage ????
bhavin24
Hi there,
I just recently purchased galaxy ace plus, the storage is supposed to be 4 gb.. but when i check from the phone setting/storage... it says
USB Storage available space - 1.82 gb
System storage - 852 MB
where is the rest of the storage? and if i could reduce that somehow?
If i download apps.. it goes into system storage.. when does usb storage gets used?
And the ram says should be 512.. it shows 398Mb total and out of that used 238 mb? is there any way to reduce ram.. uninstall preinstalled apps..safe?
It's because some of the RAM is used to run your phone (lockscreen, phone functions, etc) and the other amount of memory is used for all the apps (camera, phone, maps, etc).
System storage is used for apps and the USB storage is when you transfer files from your computer to your phone (I.e: music, videos)
Hope I helped!
Android's storage is partitioned into different parts;
There's the system partition, where all the apps are installed on, and there's the microSD (internal or external, or both) that is where you store your music, pictures, videos, documents and whatnot.
Most of the games (that are large in size) can be moved to the SD card, so you won't waste so much space of the system partition.
Hope this helped.
Hello, sorry for reviving this thread, however, if the phone functions take up the rest of the ram, why does the phone lag as hell when I'm using more than 350 mb ram? that includes when ppl call me, it takes ages to 1. light up the screen 2. match the number calling with a name from my phone book? seriously sometimes it takes more than 3 seconds to show me the name of the caller.
also, if I root the phone, can I allocate all the 512 mb ram to the processes I like?
thanks in advance
thanks in advance
Rooting a phone doesn't provide that option my friend, however it can be made possible by some tools and tricks but normally, I dont think u can allocate ram to any process in android... Btw it is not recommended in any case, result will be constant freezes and crashes. Android's ram management is far different from windows, it frees its ram when feels the need, that's why app killers are considered potentially harmful to android but if you want then try "Clean Master"
It depends entirely on what apps you use. You may have set too many apps to remain active, which is why the phone is slowing down because several apps are taking turns activating to perform their functions. Some examples are launchers with too many widgets. ALso some apps use more resources than others. For example, Go Launcher is slower than Nova launcher on the same phone with the exact same setup. Use of task killers to free up RAM also contributes to slowing down the phone in the long run.
